Thermal compound on CPU pins - any problems?
Juardis
As I was removing my heatsink and cpu to clean the seating surfaces prior to reattaching the heatsink, I managed to get some thermal compound on some of the pins. I immediately cleaned it off with a paper towel, then used rubbing alcohol to make sure I got it all, but there is a slight discoloration left behind. I put everything back together and the cpu seems to be operating fine, but just wondering if this has happened to anyone else before and if so, what was your experience?
what kind of compound? If it's electrically conductive or has capacitive properties you may have something to worry about if there is any left behind. I've gotten non-conductive paste on cpu pins before and had no issues though.
Won't make a difference. Even if it was conductive paste, the only way it would cause problems would be if the pins were bridged, which is obviously impossible since you cleaned off all the compound already.
