I had to order a new palm rest for my laptop which required me to remove the heatsink. So I cleaned cpu top and heatsink with 70% Isopropyl alcohol, and sandpapered the heatsink a bit with 400 grit sandpaper and used thermalright compound. My temps when using "realtemp" are 45-50C and when using a lot of programs it goes to 60C sometimes 70C. The fans are always on full now instead of turning off when the temp is lower, which it use to do.
Does it take a while for compound to settle and dry to become cooler?
Should I try another thermal compound?
Any suggestions?
Inspiron E1405
Intel Core Due T2350
Any suggestions?
Inspiron E1405
