thermal adhesive question
d4nnn
well, luck has it someoen has put a heatsink on the southbridge chipset on an amd system.
with thermal adhesive.
anyway this heatsink is in the way of using a slot so i am wondering if there is any wya to remove the heatsink that will not result in destruction of a perfectly good metherboard?
i think the arctic adhesive stuff was used on it.
