Hi fellas!
If one must choose, would you choose thick radiator or thick fans (wich generates higher static pressure) ?
I have found a fan type that is only 15mm thick, and I wonder, will a deeper radiator be more benefitial than higher static pressure?
Here is the fan I was talking about:
http://www.prolimatech.com/en/products/detail.asp?id=1906&subid=1908#showtab
Here is a noctua fan:
http://www.noctua.at/main.php?show=productview&products_id=65&lng=en&set=1
As you can see, the thicker fan has approximately twice as high statick pressure.
Will 10mm of extra rad depth be better or worse, and how do you guys think that will apply on my intended use as described below? I am mostly interested in how this will work in pull configuration.
I have a fractal design R4, with an i5-3570K and 2x Radeon HD 4890 cards that I will be watercooling this fall. I have approximately 50mm of space for the radiator in top of the case.
I will use the the front as intake, and the top as outlet (exhaust.) I will use 2x 140 mm fans in pull configuration between the rad end the case top.
Thanks in advance!
AlC0
Thanks in advance!
AlC0
