So a while ago I found a slick little patch that lets a person use 3rd party themes through the windows theme manager. With SP2 it no longer works. Did anyone else here use that, and if so, have you found a new one that works under SP2? LMK
I assume your referring to the uxtheme.dll trick? You can find versions for SP2 online with some searching. But, if your going to go the totally legal route, I recommend Windowblinds. Works awesome, and the resource usage is real low.
