- Mar 31, 2005
Ok,
I do in home PC repair, and 2 days ago I found myself a a ladys house because her RAID-1 failed and she needed a new drive.. Sounded simple.. Replace drive, Mirror working drive and be done.. I have now spent nearly 2 days straight trying to get this thing up and running.. this PC is 7 years old and MUST work based on the fact that the PC was a custom build for the business she works in and has a piece of proprietary software that would cost 1000$ alone to replace..
HARDWARE:
20gb+20gb RAID1 (Fasttrack raid card)
800mhz P3
128mb SD Ram (100)
CD Rom
3x PCI cards required for business to answer, route and record phone calls on 4 phone lines
Windows 2000 Pro
The PC is stuck in a cycle of endless reboots, no BSOD or error messages even with options in BIOS turned on to not reboot. There is no certain point that it reboots, its completely random. Sometimes ill reboot right when it starts to load windows, sometimes itll do it after 20 minutes.
1) Replace BOTH HDDs, Mirrored each individually for testing
2) Replaced RAM (Tested all 3 Slots)
3) Removed all PCI cards (aside from RAID)
4) Removed Drives from RAID array, removed card, tried running all 4 drives old and new on IDE alone
5) Repair installed Win2000
6) Replaced PSU
Only things left are CPU and motherboard, Even after 7 years of almost 95% uptime the thermal paste was still wet, Minimal dust (Couple bad areas). In the times I could get windows to run stable i would benchmark it, sometimes it would fail, sometimes it wouldnt. It may reboot 30 times, and then all the sudden itll work for 20-30 minutes.. Temps check in completely normal, drives have all been tested with spinrite.. Have looked over the entire board for leaking caps, and reseated CPU and BIOS chip..
What else could it possibly be??!!
This thing has been running perfectly fine for years, what would cause this sudden onslaught of problems?? My only guess is a failing L2 cache, but that doesnt explain the whole failure.. There is something ive totally missed..
Ive been pulling my hair out for hours trying to get this thing fixed.. this is her work PC and NEEDS to be up and running ASAP
HARDWARE:
800mhz P3
128mb SD Ram (100)
CD Rom
Windows 2000 Pro
6) Replaced PSU
