The Witcher Eyefinity
Intel_Hydralisk
So I decided to revisit this game with eyefinty. In game everything works fine, however the cutscenes pretty much don't work graphically (the audio and dialogue subtitles still work). I have the latest patch (1.5)
Anyone know how to fix this?
I just started the game and noticed the same problem. Did you ever find a fix?
Just wanted to share a workaround I found. Setting the Lighting Quality to "Low" allows the cut-scenes to play correctly. Not ideal, but better than no cut-scenes.
