The weirdest thing?
The heatsink/processor probably isn't seated properly, also check them RAM and make sure it's all the way in there.
When you lay the computer sideways it's probably allowing whatever isn't seated properly to make the connection and allow your computer to turn on.
Thing is, this all started when i plugged in my new Leadtek TV tuner. I have no clue, but when i take it out everything is just fine and dandy. I did a driver update and reseated the tv tuner in place, i think that should help it.
Reseated, reinstalled drivers and everything works like a peach :)
Thanks for the advices though.
