BeernuT said:K8N-VM
Overclocking Options:
* = FSB
* = vCORE
* = Mult.
* = vChipset/vHTT
* = vDIMM
* = FSB/PCI/PCI-E Locks
* = DRAM Timings
FSB - bios max 240 (atleast with my sempron 3100+ installed)
vCORE - no vCORE adjustment
Mult - Sempron is locked. Unsure if a new section pops up with a cpu that isn't locked.
vChipset/vHTT - no vChipset/vHTT adjustment
vDIMM - no vDIMM adjustment
FSB/PCI/PCI-E Locks - appears to be auto locked.
DRAM Timings - has a decent timing section in bios
MC FLMJIG said:Epox is back.
Do you guys think an Xp120 will fit on that thing? Taking the chipset off and putting in the Zalman passive chipset cooler there?
I have a Tforce6100-939, Tforce6100 and Geforce6100-M7. The latter two are socket 754. I do not have a Geforce6100-M9. Here's my take based on my experience...defunct said:Is there a difference between the Biostar GeForce 6100-M9 and TForce 6100-939?
That portion of the power section is ommitted on the non- "T" boards... The cans are used instead of the hybrids because of the difference in the power section. The hybrids are rated at 2.5V, and IIRC are used for bulk filtering, with the big cans up front for the voltage regulator...Zap said:Circled in GREEN are solder pads of components on the Tforce board that are missing on the Geforce board, with the spot reserved but nothing there.
cbecknet said:I can't find the Abit LG-80 for sale in the US only the LG-81, but I need the LG-80 for firewire. Does any one know wher I can buy the LG-80 in the US or outside the US that will ship international.
Thanks
What exactly does this mean? All Pentium M cpus I have seen are S479, not actually 478?Intel Pentium M (Dothan / Banias)
Note: On Intel Pentium-M/Celeron-M Dothan CPU, with a choice of 478pins and 479pins P-M CPU socket, MSI designed 478pins P-M CPU socket on this board
Lil Big Mec said:What exactly does this mean? All Pentium M cpus I have seen are S479, not actually 478?
Dillusion said:The MSI Dothan board... 915GM Speedster-FA4R!
Zap said:It looks pretty feature complete... lots of audio outputs and optical SPDIF, dual network, PCI-E 16X, able to use DDR or DDR2, has a P4 retension bracket for potentially "normal" HSFs... all in a sexy black that of course adds 2% performance.![]()
One concern of mine is the layout - the CPU socket is darn close to the wrong edge of the board. I know for a fact that this will make the board NOT fit in these mATX cases that I have (slim desktop) because as is the drive bays barely clear the RAM on my board. Other mATX tower cases have the HDD bays right there and the HDD sticking out may hit the HSF.
Now to find out how overclockable this puppy is.Anyone? I'd personally prefer this over an Asus board with adaptor because this has PCI-E.
WarlordOne said:It won't have any trouble fitting in a case as long as you use the provided heatsink.
Also as of now it doesn't appear to be that great of an overclocker. The only overclock review I found was a PM 760 going from 2.0Ghz to 2.3Ghz...
ALYNCH75 said:Kill this thread this is getting ridiculous
Dillusion said:Got linkage? I downloaded the manual from MSI's site and theres NO BIOS OC options, is it thru corcell VIA windows?
El Nacho said:why isnt this stickied anymore
had to look around for it
killzone said:Ive had nothing but luck with my dfi rs482 no i/o performance issues at all great little board
[LYL]Homer said:Great thread and thanks for maintaining it Dillusion. Is there any chance the tiny * can be replaced by a color letter or a larger symbol for those of us that are a little color blind?
Or there are 11 smiles you could code with....![]()
MC FLMJIG said:Great thread! Very helpful and just ordered the ABIT... let's see how this puppy does.
That MSI looks nice too. IS it worth going back to 478 for Yonah though?
The LP81 looks more tempting but nowher in site. Rather had optical than VGA.
MC FLMJIG said:I should get the ABIT on monday. I get too hooked on these things once they arrive so I'll post what I get on the weekend.
MC FLMJIG said:Abit LG-81
Doesn't look good. I can't even reach 150FSb (P 805D which does 200FSB). It came with really old bios. Flashed it and let's see what happens...
This stock fan really is a piece of junk. They should charge a bit more and put a high quality one in there.
