- Jul 1, 2004
Is bigger better?
Bigger is always better. For instance Jennifer Connelly's tits is better than Melissa George's tits.
Is bigger better?
Happy Hopping said:Bigger is always better. For instance Jennifer Connelly's tits is better than Melissa George's tits.![]()
ijozic said:I don't see how can this stand for programming/web/etc. Having a 30" screen farther so it has the same relative size as a 24" with a much higher resolution doesn't equal reduced eyestrain in my logic. Care to explain further?
Only up to a point, then it becomes harder again...Chernobyl1 said:The closer things are to you the more effort is required to focus.
Having a screen further away is less strain on the eyes.
lol, how big is your front room?whoster69 said:Only up to a point, then it becomes harder again...
Chernobyl1 said:lol, how big is your front room?
My screen is 4 metres away and is really relaxing to view.
joshley said:4 metres?!? Do you do any work on that screen? At WQXGA resolution there is no way I'd be able to read the text on my monitor with it 4 metres away - not without seriously increasing the font size and or some serious squinting/strain, which I like to avoid cos it screws everything up (I've found, anyway!). Now, I still agree that the closer something is, the more difficult it is to focus. But there is a sweetspot, and I think for programming etc. it's not 4 metres away!
Chernobyl1 said:
I have a 2.9 metre screen which is how I can sit this far away (see my specs).
Its by far the most relaxing way to use a PC.
Hope your new monitor works out well![]()
