Recently I was on a thrift store trip and saw this typewriter and thought, time for a case mod!
(in one piece)
(cover off)
I got all the guts out and started cutting, removing a lot of little mount points and stuff for the typewriter so i could lay out my system board.
Here I have cut out space for the optical drive, which will be a DVD burner from the system in my sig. Unfortunately the system in my sig has a bad motherboard or ram or cpu, and i cant pinpoint it. Every time I replace something, something else breaks. So I gave up on it and am starting from scratch.
here you have my layout plan for the system. All the parts you see here are dead, becuase i hadn't picked up an old machine from my grandma yet that is going to make up a lot of the parts.
Unfortunately I realized that I hadn't used that keyboard in years, and so when i tested it on my laptop and another machine, it didnt work. I had cut the case a lot for it, you can see in the pic with just the burner that shows you how much I cut out of the upper half of the case so it would mount in the posistion I have it in the other pics. The IBM keyboard I am going to use instead is a little smaller, so i have to find a way to fill the gap its leaving...ill upload some more pics tommorrow when I start mounting the actual mobo i will be using and stuff.
The computer I got from my grandma is an old Compaq with a K6 (or K6-2) for the CPU. The system board appears to be MATX like the one above from the 10 second look I got at it. The thing is older than I thought though because I did notice 2 ISA slots on the board in addition to a few PCI. Since my iBook only has a 40 gig hd, im going to put the 2 HDs from the AMD sys in my sig into this and load fedora to run a samba server, probably mostly in CLI or that other xwindows system for POS computers.
will update tommorrow
(in one piece)
(cover off)
