The tripple buffering trick doesn't work in BF2
RooK
Just thought I would let it be known that while it does work, it will get you kicked for an unknown windows API function. (by punkbuster enabled servers.... why would you play anywhere else??)
If tearing is bothering you, just set the frame cap to whatever your refresh is...
I have V-Sync and triple buffering enabled and working fine.
Or is this a reference to some kind of ha><?
*Edit* Never mind, I missed the article on the front page, I'm suffering from TES Blindness, I can only see articles about Oblivion.
I just force Triple Buffering in the (Nvidia) driver control panel, works fine for me.
I kinda doubt that. TB only works for OpenGL games right now thru the drivers.
That is inconsistent with my personal experience.
I don't have time to double-check, but I will be installing my 7900gtx when I get home from work this evening, and I'll run some tests, but my BF2 framerate definately doesn't drop as low and feel smoother with v-sync+TB enabled in the drivers on my 7800gtx..
triple buffering in the nvidia panel only applies to opengl games. You have to enable it using third party software if u want to use it for directx games
I stand corrected, I just tried it and there was no appreciable difference on the FEAR performance thing.
Guess it was just psychosomatic.
It is also possible that I just have my bf2 framerate capped at 60 using "game.lockFps", it's a long time since I fiddled about with the settings.
