The Sunin Steamroller!
<looks off into the distance>
Yep, I recon trouble is commn'
Hmm that is what my girlfriend said... :eek: hehehe :p ;)
Yeah unfortunately unless my side business takes off this will be the end of the new builds. I may make 1 more using the E6600 as a media center host and still use it to fold. I'm saving to buy the condo I'm renting and that ain't cheap in Chicago... :(
And I had just cleared my threat list...damn!
EDIT:Sunin, I noticed all of the RAM in your sig is listed as GDDR2, which I believe is only for graphics cards. Try changing it to DDR2, or maybe [H]DDR2 ;)
Well everyone will get a bit of reprieve from the inevitable. I have begun the move of my boxes into my closet, thus for some amount of time some boxes will be taken down.
On top of that I just got my email from EVGA about my 680i upgrade and thus the E6600 machine will be going down. I'm going to time this with my Q6600 build as to make it such that I don't lose huge points..
So run run why you can! Fold [H]arder while you can!
