The shuttle 400 watt psu?
Chris_B
Can anyone tell me if this psu has its own dedicated pci express power connector or is it a matter of using a molex > pcie connector again?
My 350 watt psu aint upto powering my 2900xt (have to disconnect the dvd rom and 1 sata hdd, evn then not totally stable), the 400 watt is pretty much my only alternative. :(
sd37p2 PSU wont have any problem with it. It has 2 PCIe power connectors.
Actually, i used to have a 7900gtx in my SN25P (350Watt) So u shouldnt have any problems.
I did however use a PCIexpress -> 2 4pin molex converter. (I split the DVDrom power cable and put into one end of that 4pin molex, and then had the other one straight in)
http://www.svc.com/pcie-converter.html
try one of those first.
