dude I got the same case as you (well the older version)
Originally posted by jpnelson83
Wait, whats IIRC mean?
BONDO!!!! That or make a little door thingie to cover the USB ports. Make it so that when you push it, it retracts up into the case.I'm just kidding. Serioulsy though I'd bondo it then you can sand that to match the contours of the bezel and no one but you and us will ever know that there was supposed to be something there.
I was hoping it was going to be polished aluminum....I've only seen one of those (the cubit) and it was cool.
just for kicks, you should reassemble the case when it looks like that for the ultimate ghetto mod
Originally posted by chinoquezada
This is first problem, see this uneveness here... Any ideas of what to do with it?
Nope, it was a beige steel case originally.Originally posted by fLiPaChu
haha. linear that was an aluminum/metal case right?
flip
edit: i'm still confused on how the gloss just "emerges" after the rubbing compound? also, would there be a difference in technique if applying to an anodized aluminum case?
Originally posted by Xeese
Give the area you filled in with the Bando another thin layer, It just needs built up a little more. The primer helps show the height issues for you.
