The Pschent ( /ˈskɛnt/) was the name of the Double Crown of Ancient Egypt. The Ancient Egyptians generally referred to it as sekhemti (sḫm.tỉ
, the Two Powerful Ones.It combined the Red Deshret Crown of Lower Egypt and the White Hedjet Crown of Upper Egypt.
The Pschent represented the pharaoh's power over all of unified Egypt. It bore two animal emblems: An Egyptian cobra, known as the uraeus, ready to strike, which symbolized the Lower Egyptian goddess Wadjet, and an Egyptian vulture representing the Upper Egyptian tutelary goddess Nekhbet. These were fastened to the front of the Pschent and referred to as the Two Ladies
The build idea was developed after watching dozens of pc case mod threads and all the inspiration i found in the community here at [H]ard forums .
Basically i`m restricted with small desk space so i can`t go for full tower chaises .... my goal is to fit a complete water cooling kit in a midi tower chaises (HAF 912 Advanced and performance PCs XSPC Raystorm RX240 D5 Kit) ... that double thick Radiator wont be an easy fit but we will see
The Hardware List for this Build is as follows :
AMD X6 1090T
Asus Sabertooth 990FX
16 GB Corsair Vengeance Blue
2x OCZ Vertix 3 SSD`s in Raid 0 and a 500 GB WD Drive
NZXT Hale 85 850 watt PSU
and of course the HAF 912 Advanced case
First thing to do .... The Haf 912 Advanced got 4 5.25 inch drive bays ... and i need all of them to mount my hardware (first bay for the fan controller .. second and third for the double bay reservoir / Pump combo and the last one for the DVD drive) ... however the case come with an internal USB 3 panel ... i don`t want to lose that functionality and i need the space it occupies ... so the USB 3 panel has to be mounted else where
I measured the clearance i got from the case feet and it fits !
So i marked where i would fit it and i marked a hole for the cable to go inside the case
And Dremel time
... DiZzzzzZzzzz
and the final mounting result .... Still Very Accessible and the bay is now free for the other hardware
and that`s all for now .... excuse my English as it is not my mother tongue
and of course any thought or comments will be mostly appreciated
AMD X6 1090T
And Dremel time
