slipperyskip
- Feb 8, 2005
Content removed.
skudmunky said:Very cool, you might want a plexi sheild around it (or does it already have one)
what does it do? Just sit there and look pretty?
rana said:are those Mini-ITX boards?
BTW....looks sweet!
widefault said:They're 3.5" Embedded format, or ECX as Intel is calling it. They're roughly the size of a 3.5" hard drive and come with CPUs ranging from a 386 up to a Pentium-M.
rana said:wow...thats tiny...
sorry for asking this but im guessing they are $$$ ....?
slipperyskip said:An HPC, or high performance cluster, is a math machine. This is not the same as a high availability cluster, which is a different subject entirely.
An HPC harnesses the power of several individual computers, specifically their Floating Point Units, to solve math-intense problems.
It does this by dividing the math problem into pieces and assigning each piece to a different computer. This is called parallel computing.
The cluster's computers (nodes) are tied together through an Ethernet connection.
The programs that make use of a cluster have to be specially "tweaked" to run on a cluster.
There are dozens and dozens of cluster software packages out there that seem to approach the task in different ways. Most of them are Linux-based. Microsoft has its version in final beta.
I hope this helps because there is a lot of confusion out there concerning the subject.
qbackin said:wow I am stupid
slipperyskip said:I don't think you could use a cluster for folding because the folding software is not written for it.
Does folding take advantage of dual core CPUs?
fenton06 said:Stanford is working on a client for clusters.
widefault said:Now build one with a stack of the Pentium-M boards you used in the DECOmputer.
widefault said:Does the Kontron have a mini-PCI slot?
widefault said:You're damned right on the I/O shields, I'd love to even have a paper pattern to use for my layouts. It's one thing that's been delaying several projects, I just hate trying to make the things fit. At least when I did my drive enclosures I could use the I/O plate from the original cases as a pattern. With these things I've yet to figure out a good way to get a layout.
Techx said:yay for the exposed power supply, hope you don't get zapped
