- Oct 22, 2004
Well, I finally got all of my parts in today, and after some work, I got it setup and leak testing. The tubing is supersized so I can just cut shorter later if need-be...first build, would rather be too big than too small. Here are some pics!
The pump! (Eheim 1250)
The rad!
The block! (Swiftech 6002)
The mixture!
Now, the main things I've learned thus far is
A. The rad weighs a ton while empty, even more with water.
B. That mixture was weak.
I followed the instructions of about 1/8th or so Anti-Freeze to Distillied Water. I picked up the pre-diluted (as instructed) and it came out looking like that. The camera's flash also adds alot of greening to the fluid, as in the tubing it was only a tint. I went ahead and thickened up the mixture and it seems alot more where it should be. Here's the loop leak testing in my kitchen atm:
The loop!
Any suggestions/pointers/congratuations would be helpful as this is my first water loop and I'm a bit nervous. Some of the parts are a bit banged up as they're used, but meh, they're all solid from what I saw, just some scratches on the finish and few bangs here and there.
Go H20!
Full Folding Ahead!
The rad!
The mixture!
The loop!
Go H20!
Full Folding Ahead!
