The OFFICIAL e6750 OC/Benchmarking/Cooling THREAD
mythek
Ok guys, let's share your current e6750 configs, stats, and benchmark results:
Plz only post if your settings are stable. And let's use my post as an example of how to correctly post.
* = Required
FPO/BATCH# L720A773
*Motherboard: Gigabyte GA-P35-DS3R (rev 1.0)
*Bios: F4
*Speed: 3600 MHz (450 Mhz x 8x multiplier)
*Vcore: 1.450
*Cooler: Artic Cooling Freezer 7 Pro
*Temps: 35 C idle and 47ish on load, and 58 on ORTHOS test (with CORETEMP)
*Stability: 7+ hours of ORTHOS (blend test)
*Ram: Crucial Ballistix 2GB PC-6400 dual channel @ 450 MHZ @ 4-4-4-12
*Ram Voltage: 2.10
*Graphic card: Evga Nvidia 7800 GTX KO 256MB @ 490 core clock / 1300 mem clock
CPU-Z validation: http://valid.x86-secret.com/show_oc.php?id=245994
*Screenshot: http://i223.photobucket.com/albums/dd81/mythek88/screenshot1.jpg
*Benchmark Results:
3DMark06 Pro:
3Dmark score: 5843
SM2.0 Score: 2198
HDR/SM3.0 Score: 2258
CPU Score: 3235
Sandra Pro XII
Processor Arithmetic: 32951 MIPS and 22609 MFLOPS
NOTE: plz quote your submission that way it's easier for people to read.
My 3DMark score is quite low...i'm guessing that it's becuz of my video card??
PornFlake
Probably so. I get over 10K with my 6750 @ 3.4 and an 8800 GTS OC'ed to 630/875.
-Funk
PornFlake
Here is my run down:
FPO/BATCH# L727A994
*Motherboard: Gigabyte GA-P35-DS3L (rev 1.0)
*Bios: F5
*Speed: 3440 MHz (430 Mhz x 8x multiplier)
*Vcore: 1.450
*Cooler: Stock Intel coooler
*Temps: 31 C idle and and 55 on ORTHOS test (with CORETEMP.95)
*Stability: 10+ hours of ORTHOS (small fft's)
*Ram: G.SKILL DDR2 SDRAM DDR2 800 (PC2 6400) 4-4-4-12 (CPU-Z Shows timing as 5-5-5-15 @ 1:1)
*Ram Voltage: 1.9
*Graphic card: Evga Nvidia 8800GTS 320 MB overclocked to 630/875
CPU-Z validation: http://valid.x86-secret.com/show_oc.php?id=248328
*Benchmark Results:
3DMark: 10724
SM 2.0: 4743
SM 3.0: 4469
CPU Score: 3088
Don't have Sandra to benchmark it.
This damn thing will not do anything over FSB 430 in Orthos for longer than 2 minutes. At 430*8 @ 1.45v it will run all day long. Push it over 430 FSB and it will take a shit. The only voltage I have messed with is the vcore. Higher vcore does not help the cause.
-Funk
-Funk
BTK17
Bios: F6
Speed: 3400 MHz (486 Mhz x7 multiplier)
Vcore: 1.425
Cooler: Scythe Infinity
Temps: According to coremp 0.95.4 with reads G0 correctly. 30C idle. 54C load. Much lower in like everest
http://img443.imageshack.us/img443/2446/orthosxu1.jpg
*Ram: Crucial Ballistix 2GB PC-6400 dual channel @ 486 MHz 5-4-4-15 (MicronD9GMH)
*Ram Voltage: 2.00
(@mythek your ram is DDR2-900 and 450MHz not 900 MHz)
eVGA 8800GTS 320MB superclock @ 610/950 - 1580 shader
http://valid.x86-secret.com/show_oc.php?id=246859
3D06 - 11,213
http://img296.imageshack.us/img296/6822/3dmark06me0.jpg
3D05
http://img216.imageshack.us/img216/3149/3d05pf7.jpg
super pi mod 1M best 14.874
why don't you require pics?
you can say stuff but does that mean i shoould beleive you?
have vista and xp dual boot but benchies on xp
just dx10 for vista
just xp/orthos/even3dmark and coretemp hate my x7 multi and think x8 = 3.8 and core temp is crazy as you can see
too lazy 2 get batch # will get later
mythek
according to ur 3dmark06 results, i notice how my CPU score is higher than urs, but my 3dmark score is a lot lower....now i know it's my video card :(
@pornflake, i think you just need to grab an aftermarket cooler, intel stock cooler sucks :(!
@BTK, yeaa you're right, it's 450 MHZ (x 2 = 900 :p) anyway hmm i cannot get my ram to run any faster than 450. everything else...it will just not post. do you thing i should loosen the timing a little bit? my ram would not run at 450 & 4-4-4-12 at with 2.0 V
and how do you get the SHADER CLOCK option in your rivatuner? i have the lastest (2.05) but i dont see it.
here's a link to dl Sisoftware Sandra Pro Business Xiic V2008 1.12.34 FULL RETAIL
Code:
http://rapidshare.com/files/55622556/fo-s12c.rar
(i'm not sure if we're allowed to post links to dl...if it's not okay, then MODS plz edit my post, or tell me and i'll edit my post myself.)
