[Redoing the waterloop
I decided to include waterblock for the northbridge in my loop. Lucky for me, the Swiftech MCW30 flow-restriction-free block was released, and I bought one immediately.
_CHIPSET BLOCK
Here's what it looks like:
And installed:
_COOLANT AND TUBING
The old coolant had stained the tubing like noones business and left residue inside the loop. A pic of the old tubing:
I cleaned the rad, pump, res, and blocks nicely. I also bought new tubing and a new coolant. Pics:
Installed and testrunning:
_SEALING THE RAD
I sealed the rad to the bottom of the case in order to prevent the radfans to suck air from inside the case over the rad. Easily solved using electrical tape:
_CHIPSET BLOCK
And installed:
_COOLANT AND TUBING
_SEALING THE RAD
