"Self Destruct" has been engaged!Xegony said:Just hypothetically, what would happen if the red switch was changed to 230v in a US outlet while the computer was on? Taking this a little further, say the computer wouldn't turn on after that... Where would the problem lie?
Xegony said:So should I start packing it up or is there something I can do?
Spectre said:Did magic smoke appear?
Elmntskater1588 said:Boom!
jonnyGURU said:I've had lots of customers do this. Even with cheap-o power supplies. The only thing that's happened is no juice until the PSU is unplugged from the wall, switched back to 110 and then reinstalled.
Your Enermax no worky at all now, eh? Hmm....
I miss the days when every Power Supply Unit came with a self-destruct switch.
Every normal PC PSU used to have a little slider switch on the back of it, see. The switch was usually red, and it was recessed so you could only slide it with a screwdriver, pen, or unusually long and rigid fingernail. What that switch did - and still does, because many such PSUs are still in service - was switch the PSU between 110 and 220V mode.
If you live in a 110/120V country (ten volts more or less practically never makes a difference; "110V" gear will virtually always work in "120V" countries, unless there's a problem with the AC frequency), then switching your PSU into 220/240V mode (those are similarly compatible voltages) will just stop it from working.
But here in Australia, we now run a nominal EU-standard 230V (it used to be 240V; most Aussies don't even know the standard's changed). In this situation, if you flick the voltage selector switch to the lower setting, there is a more than trivial probability that you'll get a flash, a bang, and some satisfying smoke 'n' stink.
If the PSU's well designed, it ought to just pop a circuit breaker in your fuse box. And if you're exceedingly lucky you'll just blow a fuse in the PSU. But I don't recommend you conduct experiments in this area; there are more entertaining ways to achieve the same results.
You can't do the voltage-switch trick with a lot of modern PSUs anyway, because they're auto-sensing units with the same multi-voltage, 50/60Hz compatibility as many modern lightweight plugpack AC/DC adapters.
natekoz said:It just shouldn't work, but lets say you plug a 110 into a 220 socket, then you would get fireworks.
scalez said:Not only did it fail, but it shot a ball of electricity about 6 inched in diameter out the psu exhaust and across the factory floor.
scalez said:i didn't say they were particularly bright engineers . . .
edit
and to mikeblas, i'm not sure if they were even running standard 220 on the floor, or if may have been an actual defective unit that fused together. i couldn't open up the psu case, or dell wouldn't have taken it back, and my manager was hot at the time about the parts budget, otherwise it would be on my wall as a trophy.
