the ISGC Rainbow [fan mod]
usrebmot
Over the past year, Ive experimented with sharpies and how they look on various things. Then I saw the Thermaltake ISGC fan and couldn't pass up the chance to do some doodleing.
Everything you will be seeing in this thread is hand drawn with no tools or projections, blah blah.
There was no way to seal the drawings themselves, with clearcoat since it would mess up the ink.
I will link all the colors when im done below.
The sharpies :)
testing with a metallic on a battery charger
preliminary drawings with green
* This Worklog post was generated using WorklogCreator - Version: 1.0.1.7
GREEN
Are you going to try and make the patterns show up with a strobe light when spinning?
That's something I haven't seen before. I think before long we will see custom fans now. Its just that cool.
MAGENTA
LIGHT GREEN
BROWN
PURPLE
Dark Blue
That is pretty awesome, something I didn't think of. I Have NZXT fans, that I can't remove from there casing for some reason, so I might just grab some blue sharpies and color them blue instead of painting.
TEAL
YELLOW
Final group shots
