hardware_failure
- Mar 21, 2008
A customer of mine had their router die (symantec vpn 100)
I am trying to setup a new router, but none that I have seem to work with the IP/Gateway config! it is as follows:
Available IP addresses: xxx.xxx.171.2 xxx.xxx.171.52
Subnet Mask:255.255.255.192
Gateway: xx.xxx.222.1
The error I get is:
"the ip address and the gateway are not in the same subnet mask" which is.. true.
Typically I have seen an IP range and a gateway to be very close to each other.
In this setup, the IPs and the gateway do not have a single octet thats even close. The symantec vpn 100's work with this setup, but they are no longer for sale.
Any suggestions?
The error I get is:
Any suggestions?
