The incredible shrinking/growing case?
vjcsmoke
What's the real size of the Thermaltake Element G VL10001W2Z?
I've seen two varying specs:
20.5" Height x 9.1" Width x 18.9" Depth; Weight: 17.46 lb
http://www.provantage.com/thermaltake-vl10001w2z~7THER0J2.htm
22.2(H) x 9.1(W) x 20.7(L) in
http://www.allstarshop.com/shop/Thermaltake-VL10001W2Z_14_23785.html
So which is it?
Has there been a slight revision, and size increase since the first one was introduced?
Also I've noticed that some versions of the Element G claim to have 1x eSata and 2x USB. While the other versions claim to have 4x USB. Has there been a stealth update to this case?
From the pics I've seen it didn't look like there was an eSATA on the front panel. As for the USB, two internal plugs each support 2 external ports...so 2x2=4 ...some spec sheets might have confuse the two.....the pic I looked at showed 4 front USB ports...
Can't say about the H-W-D although 18.9 isn't very deep...
Maybe they have big manufacturing tolerances... :p
(would be perfectly understandable for that brand)
That's a difference of 3 inches though. That's not a 'tolerance' that would be like a mini redesign.
Does anybody actually own this case and can comment on its true size?
Also do 10.5 inch video cards fit without a problem or do they end up to snug against the internal drive cage?
Newegg also has this case listed at the larger 22.2x9.1x20.7 size. And I generally trust Newegg.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133086&Tpk=thermaltake element g
Newegg also has a combo featuring the Element G case + the EVGA Classified 760-A1 which is one of the bigger motherboards out there.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.246240
I'd think they'd have a lot of returns if the Classified wouldn't fit into there...
