The Impossible case !
fightingfi
Looking for a pc case that has a 200 mm on top and able to support 140 mm fans in front and back does one exist ?
This does, but it's MASSIVE. It should be back in stock soon. I use one for my server.
https://www.newegg.com/Product/Product.aspx?Item=N82E16811147157
Front (first layer): 2 x 140mm Red LED Fan (pre-installed)
Front (second layer): 2 x 140mm Fan (pre-installed)
Rear: 1 x 140mm Fan (pre-installed)
Top: 2 x 230mm Red LED Fan (pre-installed) or 3 x 120mm / 140mm Fan (option)
Side: 1 x 230mm Fan (pre-installed) or 9 x 120mm Fan (option)
Bottom: 1 x 120mm / 140mm fan (optional)
Its not that big. Try the Thermaltake Core WP100 or 200 series.
