velusip
- Jan 24, 2005
Running into a lot of errors since upgrading from a low watt AM2 to a Phenom core. Also changed memory from Mushkin to G.Skill. Lots of testing in store to find the problem, but here it goes:
I just came home to this after my first trial of the non-gpu smp client. So many things have changed recently it will be tricky to track down. It's really discouraging because up until my last computer upgrade folding at home ran flawlessly on multiple computers for the past several years non stop.
Code:
[17:07:11] Completed 60000 out of 500000 steps (12 percent)
[17:09:43] Quit 101 - NaN detected: (ener[20])
[17:09:43]
[17:09:43] Simulation instability has been encountered. The run has entered a
[17:09:43] state from which no further progress can be made.
[17:09:43] This may be the correct result of the simulation, however if you
[17:09:43] often see other project units terminating early like this
[17:09:43] too, you may wish to check the stability of your computer (issues
[17:09:43] such as high temperature, overclocking, etc.).
[17:09:43] Going to send back what have done.
[17:09:43] logfile size: 8783
[17:09:43] - Writing 9333 bytes of core data to disk...
[17:09:43] ... Done.
[17:09:43] - Failed to delete work/wudata_01.arc
[17:09:43] No C.P. to delete.
[17:09:43] - Failed to delete work/wudata_01.sas
[17:09:43] - Failed to delete work/wudata_01.pdo
[17:09:43] Warning: check for stray files
[17:11:43]
[17:11:43] Folding@home Core Shutdown: EARLY_UNIT_END
[17:11:43]
[17:11:46] CoreStatus = 7B (123)
[17:11:46] Client-core communications error: ERROR 0x7b
[17:11:46] This is a sign of more serious problems, shutting down.
Dialog:
"Folding@home has run into a serious error running the core. and will shutdown."
