TheArkratos
- Nov 20, 2017
I have not found a single slot 1070 to test with. I was able to run two Quadro P4000 on the bifurcation.
Just barely smaller than 3 slots. Designed exactly for that layout you have imagined, and windows on the side are a yes!
Only concern I have is that maybe the radiator needs to be in bottom, for cold air in bottom through rad, hot out top.
The reason I ask is if I wanted to run a single slot capture/usb/raid/ethernet/wireless card and a dual slot graphics card. All of the 20 series cards have dual slot IO at the minimum, not to mention if someone wants bifurcation and is not watercooling. So unless I go with watercooling Vega or an older card the bifurcation is a little pointless if you want to be on current consumer hardware.
