Given the current state of PC based audio, then introduction of Windows Vista and current trends in the market what do you guys see for the future of PC based audio?
Btw does it matter which equipment do the decoding? As long as there is no DSP involved, I think that it will still sound the same because the compression is used due to the bandwidth limitation of the optical drive in the first place.
This would be preferable because then you can still have simultaneous playback of other audio sources on your computer instead of having them blocked out by the pass through of TrueHD/DTS-HD material (like you know how when you watch a movie while passing through ac3 or DTS you can't hear any other sounds going on your computer, this can be avoided by HDMI).
