The final decision - ( Radiators )
Davey
Alright i have a Coolermaster Praetorian and i want to wc it obviously but im trying to decide wether i want to use a dual 80mm radiator ( Sticking it in the front where the 2 80mm fans are currently ) or putting 1 80mm radiator on the back exhaust and 1 80mm radiator in the front
How will this affect performance and what are pros and cons of the dual vs single radiators
Btw i plan to get a blackice radiator
It's better to have one larger one than two smaller ones becuase you have less flow restriction as a result of moving in and out of a radiator. If you are willing to cut up your case a bit I would saw off those drive cages in the front bottom and put a single 120 mm radiator there, but if you want to stick with the 80's get a dual 80 for up front.
Yah i like the way the drivebay makes the case look inside :( Alright thanks though :) it helps
