The Dual Xeon Blues
Status
Not open for further replies.
nitrobass24
[H]ard|DCer of the Month - December 2009
Well i got my X8DTL-i in tonight for E5530's and the darn thing wont boot.:(
It gets stuck at checking NVRAM, so i reset it and i changed the BIOS to clear the NVRAM on boot.
This time it says NVRAM Update Failed.
What could cause this?:confused:
Mr EvilAlchemist has the answer. Check you PM!
It is a easy fix so do not worry to much! All will be good soon!
EA saves the day!
Posted via [H] Mobile Device
Status
