I'm having trouble installing a PCI wireless card, TP-Link WN851N. When I install the drivers I get the device manager error, "The Device Cannot Start (Code 10)," so I can't connect to any network. I'm using Windows XP SP3 32bit.
I've tried the following:
Uninstalling drivers and reinstalling
Uninstalling the device from driver manager
Installing new drivers
Installing new drivers with windows "new device has been found" utility
Moving the card to 3 different PCI slots
Removing all other PCI cards (sound card)
One curious thing, when I try to install the new drivers I downloaded, I first have to uninstall the previous drivers, and it uninstalls them for a while and seems to have uninstalled them, but at the end it gives a message: "The driver files you wish to remove will not be removed as the corresponding card is not inserted."
Is there any way to check if the actual card could be damaged? I assume that since it is being recognized by windows in some way that it's working, and is having some kind of conflict which I do not know how fix, but the status LED's on the card itself are not working.
