The dead computer and the sub woofer
DthInd
I build computers for friends on occassion as a side job. A year ago I built a Shuttle SFF for a friend.
Shuttle SN25P AMD Socket 939 AMD Athlon 64 FX / Athlon 64 / Sempron NVIDIA nForce4 Ultra Barebone
BFG Tech BFGR68256OCX GeForce 6800 256MB DDR PCI Express x16 Video Card
CORSAIR XMS 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit Desktop Memory Model TWINX1024-3200C2PT -
NEC 16X DVD±R DVD Burner Black IDE/ATAPI Model ND-3550A - OEM
AMD Athlon 64 3700+ San Diego 2.2GHz Socket 939 Processor Model ADA3700BNBOX
Windows Professional OEM / regsistered with Microsoft.
i got a call last week, they said it died. All it would do is get to a boot screen and say that a command file was corrupted and insert the OS disk and try to repair. They dont know how to do that, so I went to their house to figure out what was wrong. I found the computer sitting on this huge sub woofer. I mean like two feet square huge.
I kind of took a wild guess and said the magnet from the sub woofer may have caused some problems.
I took the thing home, hooked it up and got the same result. I even tried to re-load the OS. I could never get past a certain point of the HD just hanging.
So here is the issue, i dont have the serial number sticker anymore, and he is moving and cant find it.
A couple of options:
1) Take out the HD attempt to hook it up to another computer as a slave and see what happens. Ideally try to recover the serial ?
2) Buy a new HD and install it, to see what happens (that is up to the point where it asks for the serial) ?
Issue being, how do I get the old serial number from Microsoft? Can I call and reference my registration and they will give me a number if the old drive is dead ?
Should I even attempt to take the old HD out and put it in a new computer, or could it be magnetized and cause damage to another computer?
Did the sub woofer fry chips on the motherboard of the shuttle ?
help ?
and thanks !
If the sub had anything to do with the computer not working, I highly doubt it's because of 'fying' it. It's also perfectly possible that a part has stopped working properly and that the sub had nothing to do with it.
On the other hand, the sub could easily have jostled the hard drive enough for it to fail. I'll bring up magnetic force, but hard drives nowadays are decently magnetically shielded, so unless the sub is crazy powerful, it's probably due to vibration. Plus, it seems the Shuttle lasted a lot longer than it probably would have if it were a magnetic field problem.
Can't believe he kept it on a subwoofer :(
Magnets don't work like static electricity. A magnet doesn't hold a magnetic charge or anything. It'd be fine if you tested the hard drive in another system.
As previously mentioned, hard drives are magnetically shielded so there shouldn't be a problem.
Sounds like it may have been dropped or bumped is what I am hearing or the HD may just have died.
