the computer i am going to build..
so this is going to be the computer i build, here are the parts:
silverstone temjin tj06 silver (i will not be using windtunnel)
dfi lanparty nf4 sli-dr
athlon 64 x2 4600+ manchester
thermalright xp-120 heatsink w/ panaflo M1A 120mm fan
bfg geforce 7800GTX
forton 500w blue storm psu
ocz 2gb platinum memory (2x1gb)
western digital raptor 74gb (10k rpm)
lite-on dvd-burner
lite-on dvd-rom
alps floppy
logitech mx518 mouse
saitek eclipse keyboard
my newegg wishlist with all that (except the dvd-burner case its outta stock) is here:
http://secure.newegg.com/NewVersion/WishList/WishShareShow.asp?ID=1594569&WishListTitle=owned
i hope i didnt leave anything out, but what do you guys think? (im obviously aiming for a top-of-the-line gaming comp, just without an fx-57)
Why are you getting a SLi board? Do you plan to get another 7800 later on?
yea. actually, thats one of my questions. will 500 watts be enough to handle two 7800gtxs at a later time?
bfg geforce 7800GTX
lite-on dvd-burner
lite-on dvd-rom
alps floppy
Don't get a HDD of any kind from Newegg. They will ship it in bubblewrap, which allows the hard drive to get damaged en route. Search around on www.ZipZoomFly.com for lower prices and a HDD. I suggest a Maxtor DiamondMax 10 7K 300gb (or 250 or 200) 16mb cache SATA drive. It has a massive amount of storage, but also a 16 mb cache. This means it is the fastest 7k drive on the market, and costs exactly the same as 8mb versions of similar capacity. Here are the links to them:
300gb $155: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=100719-4
250gb $114: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=100718-5
200gb $97.50: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=100713-3
Raptors are an extreme waste of money. The Maxtors will be almost as fast (you probably won't notice much of a difference) and you will get 4x the storage for the same price.
If you are worried about dual 7800s, here are two very reliable PSUs:
Seasonic S12-500 $105 http://www.case-mod.com/store/seaso...-500-watt-atx-power-supply-p-1579.html?src=fr
Seasonic S12-600 $130 http://www.case-mod.com/store/seaso...-600-watt-atx-power-supply-p-1580.html?src=fr
The S12s are made to be quiet AND efficient. You seem to have a large budget, so I suggest the S12-600 to be sure you can handle SLI.
It's your choice to get an XP-120, but I would get an XP-90 and save a little money. The NON "c" version is like $27 and will cool your cpu within a few degrees, maybe even just 1-2c, of the XP-120. Get a panaflo either way.
"athlon 64 x2 4600+ manchester". I wouldn't get this. A 4200+ or 4400+ will cost a LOT less, and will give the same performance, especially with an XP-90 or XP-120. All these cpus top out at about the same total speed, so if you have the cooling you can get about the same performance that someone with a cpu 3 times as expensive with the SAME cooling can get. A 4200+ coupled with an XP-90 will easily hit about 4800+ speeds. So save your wallet, or just get another 7800!
I don't know how much this costs, but you are probably wasting your money. You can get 2x1GB for $160 here:
Mushkin SP 1GB $80 http://www.newegg.com/Product/Product.asp?Item=N82E16820146190
or $212:
Crucial Value 1GB $106 http://www.newegg.com/Product/Product.asp?Item=N82E16820146545
The Crucial ram is proclaimed by (cf)Eclipse (a very ram knowledgeable person here on the forums) to be able to do 2-2-2-5 at up to 235-250mhz. The Mushkin SP is POSSIBLY based on the same chips, so it could do the same thing, but no one has bought any before. (I am buying some this week hopefully, so I will be able to tell you soon.) Your choice. But don't waste your money on anything that costs more! RAM doesn't increase your performance very much beyond a certain point (which the Crucial and Mushkin is at!)
bfg geforce 7800GTX.
Go to www.ZipZoomFly.com and you can get an XFX 7800GTX clocked at 490/1300 (as opposed to the BFG's clock of 460/1300) for $550. Or other ones that are slightly lower clocks (you can always OC them to just as high speeds) for as low as $535. AND free shipping. With the savings from the rest of your sytem, why not get two 7800s now?
I have no problems with your mobo, case, fdd, opticals, keyboard, and especially not your mouse (awesome mouse). I suggest you get a fUNC pad to go with it. Good choice on the mobo btw.
The computer that I have outlined will be just as much of a gaming powerhouse as the one you initially had. The only difference is price. Alternatively you could add a second 7800GTX to my build for the same price (depending on which of my suggestions you took), which would obviously blow the first system out of the water!
Edit: took a look at your wishlist. noticed your price on the mobo is $200!!!! This is waay unnecessary. Check out this one which gives you the same functionality for $166:
http://www.newegg.com/Product/Product.asp?Item=N82E16813136157
That's about 20% less!
i know that newegg isn't the best price on everything, but the thing is, does zzf have a good rep? because id rather order all my parts off one website if possible (and if it means getting ripped 20-40 bucks, then im fine with that). i just know that newegg is very trustworthy as far as returning items, customer service, etc.
anyway, aside from that, im now going to get the 4400+ instead of the 4600+ (yea, 300 bucks isnt really worth that lol), im getting the maxtor diamondmax 200gb hd, the crucial ram, and the seasonic 600w psu. i guess ill consider using zzf for the geforce, but will someone reassure me about zzf?
but yea, ty for the help. :)
__
edit: one more thing. about the xp-90 vs xp-120, won't getting the xp-90 be more noisy since its a 90mm fan instead of 120mm?
Woahh man sound like one killer set up, you picked one killer mouse and keyboard, i have used that mouse before at my cousins house its awesome.
It's no diamondback, but it gets the job done :D
ZZF is a very reliable e-tailer. I'd say the top three (for computer hardware) are Newegg.com, ZipZoomFly.com, and MonarchComputer.com . And ZZF and Monarch have lots of free shipping deals, unlike newegg.
ZZF and Monarch currently have much lower prices on 7800GTXs, for the most part (well, not like $100, but a good amount when you factor in shipping).
The main reason I'd use ZZF for a HDD as opposed to Newegg is the shipping problems with Newegg. There's a thread where someone quoted 5 major HDD manufac's policies on RMAs and they all said that RMA'ed HDDs shipped in bubblewrap will be rejected. Newegg ships HDDs in bubblewrap.
The noise on any heatsink depends on the fan you buy with it. If you are willing to spend the money on a XP-120 and it fits in your mobo, then yea I guess you could get a better cfm : dBA ratio. But just be aware that's the only real benefit that you are getting for the extra money.
Why in the world would you order a floppy? And what's up with the $18.00 Panaflo fan??
Other stuff looks pretty good. Best of luck with the build!
ZZF rocks and is about the same price as newegg when you consider ZZF gives you free 2day while newegg charges a few bucks for 3day shipping. About the only problem with ZZF is they have small selection compared to newegg.
As for HD shipping, while it is technically incorrect to bubble wrap a HD, I don't see how the thick layer of bubble wrap newegg uses is any worse than the little foam container ZZF and others use. But naturally you should always use packing approved by the manufacturer if you have to RMA a drive.
one question, will that system be able to play bf2 at 1600x1200 max details w/ some sort of AA and AF on? (play it well, i mean)
...says the man who has obviously not owned a Raptor.
LOL I was gonna say the same thing. If you want speed, get a Raptor. If you want space, get something else. Raptors ARE a waste of money if you need 30,000 terrabytes of space... But really... how much space DO you need?
dammit, i already ordered a maxtor. but i did hear from lots of people that its much faster than most harddrives, obviously not quite as fast as the raptor, but not that much slower.
That's exactly right. The Raptor is only a little faster than the Maxtor according to benchmarks. But hey... "only a little" is a very relative term. So... you be the judge. ;)
hahaha. i guess its not that big of a deal, my system should run just about anything well.. i hope.. :-P
well the only reason i didnt go with the raptor is i heard it is quite loud compared to other drives.. that and the fact that for 60 bucks less, i could get 200gb with maxtor..
I wouldn't say "quite a bit" louder. I'd say "barely louder". See... it's like this: If you've got a bunch of fans in yer case, you ain't gonna hear the difference. If you wear headphones or have your speakers loud, you ain't gonna hear the difference. If you've got a well-insulated case, you ain't gonna hear the difference. Now... if you put your ear up to the drive, you will hear a smaaaaaaall difference. I went from a Hitachi Desktar 180gxp to a Raptor 36gb and I canNOT tell a difference. Granted, the Hitachi was a bit dated, but that's sayin' somethin'.
haha damn. shoulda waited before i ordered. although i do kinda want that extra space for linux.
*question again*
would 2 200gb maxtor diamondmax drives in raid 0 be a lot better than one? in reguards to the upgrade in space, i know yes, but speed wise?
*question again*
I don't have any personal experience with RAID 0, but all the benchies I've seen mark a performance increase. Not sure about the price/performance ratio, but you will speed up your read/write times.
If you need the space, you can't go wrong with the new Maxtors. It will definitely serve you very well.
Here's a review from http://geek.pricegrabber.com/rating_getprodrev.php/product_id=3173558/id_type=M
It was a tough choice between this drive and the raptor but in the end I decided I just needed more than 74gb of storage. All the online reviews I read suggested this drive was almost as fast as the raptor but with far more capacity. After I installed it I checked the speed with a diagnostic tool called sandra. I then did the same with the raptor hard drive on my fathers computer. The raptor was somewhat faster at 56 mb/s, but the diamondmax10 still blazed at 48 mb/s. Considering the 300gb capacity of the diamondmax10 versus 74gb for the raptor I conclude the maxtor gives more bang for the buck. Almost as fast, huge capacity. You decide. Im very happy with my purhase
