Thanks for the comments guys. I've been leaning in this direction. The only reason I'm hesitant is because then I would have to put the drive cage back in to mount it. Not sure how much this would affect the air flow.
It would be better looking than a gaping hole in the front of my case. Does anyone know where I might be able to find a replacement 3.5" drive bay cover? I'm 99% positive that they don't make them for this case any more.
A bit of an update - I dremeled down the excess on the rivets; took some pics I'll upload when I get a chance. The panel fits better, but it still won't completely slide on.
Also, I got some feet! They're just el-cheapo ones I found at Frys for $0.50 a piece, nothing special, and they're just taped on with double sided mounting tape, but they do the job. I'll take some pics for those too in a bit.
Cool on the feet, I wonder if there is a way to mount the controller without the hard drive cage. I hope everything comes along smoothly for you, I was cleaning my case removing the old hd's and putting a fresh copy of win 7 on my computer when the cooler broke off of my graphics card... yay. Now im using the leg burner.
