Originally posted by Giblet Plus!
They're both shit.
Build your own:
http://s88005051.onlinehome.us/articles/water1.html
Originally posted by OneMadPoptart
I have owned a koolance, and I can firmly say:
Yes, it is shit. For a first-timer in watercooling its great, but as far as the best cooling solution, it simply cannot run with a 1/2 ID, 300+ GPH, 120mm radiator system. The DIY systems also run on less and larger fans and are extremely quiet. Much more quiet than the Koolance at low fan speeds.
Thats my opinion. Think of it what you will.
Originally posted by oqvist
This from someone who obviously never owned a Koolance![]()
Originally posted by jungleslang.nl
You need the best of the best so. The best block, the best rad, the best pump etc.
Couple good products: Cascade/RBX, BIX/BID/Heatercore, swiftech mcp600, 1/2" Tygon tubing, reservoir.
Yeup. I don't buy shit just because kyle bannit does.
Koolance makes toys. If someone is going to spend $220 on a toy watercooling setup, it better be way better than a $30 heatsink. Koolance setups aren't.
Show me a Koolance setup that can handle 2.15V.
Originally posted by JMke
the Koolance, Corsair and Asetek Waterchill kits are easy to install, deliver good performance and introduce you into watercooling; I you want more performance and a better setup you'll have to look at custom setups like Dangerden/Swiftech/D-Tek and others offer. Or go all out and build your own waterblock in combo with a Porsche radiator![]()
Koolance setups are 100 % better than high performance air cooling. Believe me I know. I used to have 6 case fans a Alpha 8045 coupled with a delta 68 cfm fan and a 50 cfm fan on top of it. I live in Sweden so I can easily get low ambient temps too.
Fans on high - c/w of .29, Fans on low - c/w of .34
http://overclockers.com/articles550/
SLK700 with TMD fan - c/w of .29
http://overclockers.com/articles649/
seems like a mounting issue with the mcw500![]()
Originally posted by kronchev
but if you DIY, whats better, a D-tek system or a Dangerden system?
Dtek White Water
Swiftech MCP600
Dangerden "dual" heatercore (or just buy the real thing, a chevy caprice heatercore from autozone)
1/2" ID 3/4" OD tubing
Avoid getting a bayres, especially if it has 90 degree fittings. They just make your system more complicated when you should be following KISS.
If you really want to run a res, make a big one out of a nalgene or something and connect it to the inlet of your pump with big (5/8 or 3/4" ID) tubing.
bah, look at my other thread for what i was considering. hydor pump, maze4 OR spir@l, and I wasnt sure if I could easily attach a fan to the heatercore (as in just screwing it in place)
also I would do inline but no place has any info on how to.
Asetek and Corsair don´t beat Koolance in the prebuild section. I think it´s quite a good testimony that you have to DIY to beat Koolance![]()
Why spend $45 for a decent block when you can spend $50 for a great one? Get the white water.
You can just screw fans to a heatercore, but using a shroud is better. If you're one of the 90% of the people on this forum that like having stuff done for you, Dtek sells premade shrouds for their Pro and JR120 heatercores.
Inline is easy. Most setups that use a res are inline anyway. I would recommend a t-line setup (KISS again). You just need the T fitting, some extra tubing for a fill line, and something to cap the fill line with.
I would avoid Hydor pumps. They have some impeller problems. Go with the swiftech MCP600, a Danner Mag 3 or an Eheim.
All it takes to beat Koolance is a $30 heatsink/fan.
Edit - Corsair does beat Koolance:
http://overclockers.com/articles373/waterkit.asp
what do I cap the line with, thats what I dont know. no places online sell it, at least places that sell the other WC stuff, and im trying to get it all from just one place, to save shipping.
ive never heard that about hydor. i will never buy a swiftech anything. i dont know who sells danner. i cant afford an eheim.
No it looses in 9 tests out of 10 to the Koolance Exos.
I cap my fill line with the top of a crayola marker.
The danner is sold at www.petsmart.com, www.marinedepot.com, and lots of other places. You have to buy your own barbs for it, and use teflon tape on them. The Mag 3 is a great buy at $40-$50. It has a 10' maximum head height (eheim 1250 is something like 6.5'), and pushes 350 gph at 0' of head.
well here's what I'm looking at, for the system in my sig.
Hydor L20 Pump
MAZE4 Block, Lucite Top, None, 1/2 Fittings, Chrome Fittings,
Heater Core Radiator with Shroud and Mounting Hardware, 1/2 Fittings
Clearflex Tubing 1/2 Inch ID 7 ft
Adjustable Plastic Hose Clamp, 11/16 - 13/16 x 10
Barbed Polypropylene T, 1/2 Fittings
4oz Water Wetter
SUNON 120mm Fan - With 4 Pin Molex
150.94 + ~10 shipping
I have 50 in my paypal now, if a certain few people who are interested in stuff would get back to me, id have the money. alas![]()
Originally posted by camay123
I have found the L20 a bit small for a pump. Are you buying from dangerden ?
well right now i'm fighting the urge to order with my bank account. its about 160, i have about 220 in my bank account. i really dont want to drain it all. i wanted to use my paypal account, problem is i only have 50 in there. i dont think itll pull from my bank account if I try to charge more to it than is in there.Originally posted by camay123
Yup. I agree. only only one block is enough. Plus the L20 is cheap and more compact.
http://www.hardforum.com/showthread.php?s=&threadid=733077
Have I offer you tubing, clamps and T fitting . Could make a special price![]()
