paw64 said:What Thermal Interface Matteral should I use?
Im looking for somethig with the highest thermal conductivty, and the longest life span.
Phrostbit said:Arctic Silver 5 has been my choice for the last couple of years.
--Phrostbit
paw64 said:But doesnt Artic Silver 5 brake down over time? And after being worked out of a joint, it wont reflow back in. What do they use in the industry?
exactly. if your temps are so high that the few degrees C that might change would be the difference between being under the temp threshold of ur cpu and being over, you're already running too hot anyways.TruthSeeker said:*snip snip*... I chose the Ceramique instead of buying more AS5 because the difference in overclocking is in my opinion, negligible.
Lothar said:Any one who has had a processor pull right out of the socket when removing a heat sink knows what I mean. AS5 can become glue like after time, I have even heard of heat spreaders or cores coming off.
Im gonna sya nopaw64 said:But doesnt Artic Silver 5 brake down over time? And after being worked out of a joint, it wont reflow back in. What do they use in the industry?
I've collected some information this new LIQUID METAL thermal compound over here
Wow, this just happened to me to...bubsie said:Holy crap, that happened to me the other day when I was removing my Zalman HSF off my p4 2.5gHZ. Thought I was the only one person had this happen, now I don't feel so bad. On a side note, this month's Maximum PC had a small comparision on thermal paste and the conclusion was, they were all pretty much even cept for some copper FrozenCPU paste. That did the worst. Their advise was as long as you some sort of thermal paste, you should be fine.
qdemn7 said:I'm going to be different. I use Shin Etsu X23-7783D myself. Yes it's a little harder to apply than AS5, and can take as long as 200 hours to fully break in, but it always gives me about 2C lower temps than AS5, it doesn't "glue-up" like AS5 does and finally it's non-conductive.
cnick79 said:I use AS2 and AS3 combined to give me the power of AS5. I kid you not.
boardsportsrule said:yep yep! i agree
