Rishy said:would it fit in a P180 on a A8N-SLI with a A64 3200 ?
jcll2002 said:
quadnad said:It would certainly fit the P180 (I'm running mine in there now), and definetly on any socket A64, but I couldn't help you about the motherboard. I would assume so, as it's supposedly "universal," but give it a google. You should be able to find someone with it listed on their sig.
edit: here's proof that it'll fit.
2gigs said:will it fit a superlanboy
EZtarget said:How about the stock 4 heatpipe cooler? It works great and can be found for as little as $15.00 w/ shipping....EZ
http://www.madshrimps.be/?action=getarticle&articID=399
http://www.hardforum.com/showthread.php?t=1010853
Ockie said:Zalman CNPS-9500
Yes, at least it fits in mine just fine. It might be close if you've modded a fan onto the side window - I'd say there's less than an inch clearance between the top of the ninja and the side of the case.2gigs said:will it fit a superlanboy
JMke said:I have to disagree here, for $70 budget you can get higher performance units like Scythe Ninja
maademperor said:Hell, I got my ninja for $36...so you could get a nice 120mm fan and the ninja for $70. or a Ninja a fan controller...a Ninja and like 8 big macs....
DangerIsGo said:the last ones.
