KazeoHin
- Sep 7, 2011
Hey guys. I am doing some research on monitors, as I may be updating my eyefinity set up. The big problem is that I run my three monitors on a sturdy 3-swing-arm stand that is terrific but only supports 22" or smaller monitors (technically it says 19" but my 19"s fit with room to spare). I LOVE pixel density. I would rather have a 20" 1080p screen than a 24" 1080p screen as the pixel density (or lack thereof) on the larger screen makes things look so blocky and jagged.
Annother big thing is that I mount my monitors via VESA, and most monitors support this, but some of them are only mounted on the plastic shell, with the internal metal structure not mounted at all. My current monitors have had the plastic shell removed completely because the bezels look soo damn good that way (less than 1-inch between viewable screens). I am able to do this because the VESA threading extends to the structure of the monitor, and the plastic shells bear no actual load, so I was able to remove them and still mount the monitors. I have repaired a few monitors in my day and MOST I've seen don't feature this sort of structural design, most monitors mount on the plastic shell, thus if I were to remove the shell to reduce the bezel area, I could not mount them. So obviously I want the new monitors to either A): have small bezels or B): have internal VESA mounts on the metal structure of the monitor.
Primarily I game and do 3D artwork, so quality is a priority, but I don't need REDICULOUS low refresh rates. My current monitors are 12ms (I know right?) so just about anything is an upgrade in the refresh department. Point being, just because I game doesent mean I need 1ms refreshing monitors. I'm happy with a 5ms with good resolution and colour.
That not particular enough for you? I also want them to be relatively cheap, as I would HOPE to updated set up with three new monitors for under $600...
Thanks for your help as usual!
