Well I have been putting this system together, firstly I had a couple of PMs regarding the mobo.
It came from overclockers.co.uk (revA3)
I have found the 912 bios to be unstable and would not recommend it unless you need it.
Q6600 SLACR @ 3.4ghz
Lanparty JR p45-t2rs @ 425mhz
4gb corsair dominator 8500C5 @ 510mhz 5-5-5-15 (PL 8, more aggressive/fully tightened phase adjust ~ 7600-7800MB/sec read/write speed)
ATI HD4850 512mb @ 750/1150 with arctic accelero S1 + 120mm fan
250gb 7200.10 seagate 16mb cache (have another one in another system but need to move it over for 2 in raid, its at the parents house lol)
Enermax 500W PSU
Zalman fan/power monitor
22" Hanns-G 1680x1050 monitor
Antec P180 mini
As I was moving the system over to the antec case I tried using the thermaltake HR-03GT to call the 4850 "passivly" with the cooler reversed to free up a slot using the 200mm fan to draw air over it. The experiment failed with stupid core temps so I replaced the S1 on it and it died.
The s1 is easy to install so I am not sure why but it did. It was a good card reaching 750mhz too *sigh* On the bright side I have ordered a sapphire dual slot H4850 (the shorter one). Ebuyer is replacing the original one so I shall have 2. Yep I am going crossfire
The shorter card is partly for cable management issues.
A couple notes on the case:
1. Awesome
2. Very quiet, I have a Noctua 120mm fan in the front and the air is moving but making hardly a sound, the front door does mask it a lot as there is a big difference with it being open/closed.
Well benchmarks soon (expect them around a week today for the crossfire tests), single card results with a lower CPU speed (in my last case) were around 8000 3dmarks in vantage:
http://service.futuremark.com/resultComparison.action?compareResultId=385976&compareResultType=19
Will post up pics soon
Enermax 500W PSU
Antec P180 mini
1. Awesome
