I always play a sniper in a team role. I'll scout (as snipers should) and tell people what to expect, i'll cover them from people sneaking up on them, and as a sniper (especially if you're a good shot) you can manage to rack up kills without dying a ton (means you're an enduring team asset.)
In Joint Ops, which imo has probably the best sniping system out there, i'll run ahead, scout, relay whats going on to my team, and then try to harass the enemy til the cavalry gets there.
One of the joys in Joint Ops is also countersniping, its a real thinkers war when its two snipers.
A good sniper isn't a loner, a good sniper is a team player. BF2 punishes (rightly) for loners, but the whole grid thing and the fact that you can't really gauge if you're going to hit your target sucks. Real sniper rifles are wholy accurate, they're designed to be, and imo the sniping system needs an overhaul... as do many of the other weapons (which are accurate to a really asinine fault, even when prone.).
For instance, the m4 vs the m16, the m4 is heavier, but shorter barreled, so it should win over the m16 for full auto but not accuracy at range... the balance shouldn't be that it is "weaker" than the m16, because they are the same bullet, and the muzzle velocity is moot. The winner for the m16 would be of course the "control" aspect of a triple shot and a single shot, the accuracy, and the m203 under the barrel. IMO, paying attention to those details would be more fun than playin on CS principals.
Joint Ops has a great weapons balance system, the real let down in that game was the way heli's were handled (something i have a problem with in bf2 as well), but hiding in tall grass actually camo'd you, so having the guille suit (sp?) was actually worth something to a sniper. There were AT4's (think sraw) and there were eventually working javelins. It ALSO had working man portable stingers, the ability to choose the weapons you wanted to use, and most importantly to this thread heh... a working aiming system.
