fallguy said:Proof is not some synthetic benchmark to me. I dont rely on them at all, I use actual games. Sismark and others show lage drop in score going from 1T to 2T, games do not however. At least from the limited numbers I have seen.
Is he at 6, or higher?
robberbaron said:If the synthetics, which are really sensitive to timings and such, show 3-3-3 1T at DDR500 to be better than 2-2-2 2T at DDR400, what makes you think games will show the reverse?
fallguy said:Dont get upset becuase I like proof for something Im being told. Its a simple question, that has not been answered yet. Is 2x1gig at Cas2.5 3-3-10-1T faster in games, or is 4x512 Cas2 2-2-6-2T faster. Nothing in this thread has answered that.
What is that you're doing the ram bench with? Ill do mine, and compare if to yours.
edit, Ill be down for a bit. Got my new PSU in, gonna rewire the case.
(cf)Eclipse said:oh boy.. sometimes i want to give up
i have single channel.. you have dualfallguy said:edit, just noticed I had 128 bit in controller mode from A64 tweaker, his was 64 bit. Whats the diff?
(cf)Eclipse said:and that was my 'quick proof'. it might not be enough, but i was hoping you could extrapolate the results and consider how superPI is effected compared to other programs, and see that there is next to no difference
robberbaron said:Eclipse proved that the 1 gig sticks will beat out 2T with 2-2-2. Crucal Ballistix are the best for latency at high densities, beating out 4x512 just because 2T tends to be more severe than going from 2-2-2 to 3-3-3.
rohcky said:Ok, I'm bad at following posts so I have questions. If I were to install 4x512mb single-sided RAM, would that allow me to run at 400mhz? What would the performance hit be like? And would I still be able to run Dual Channel?
I read somewhere on here that Dual Channel gets diabled when theres more than 2 dimms, yet my mobo manual says I'm able to use Dual Channel with all slots filled. Would appreciate it if someone cleared all this up for me.
rohcky said:Winchester
robberbaron said:Gee thanks for getting a core that was made during the transition between stupid and good memory controllers!
rohcky said:Yea... I was stupid. My friend asked me for tips on building a pc. That got me excited and I decided to build myself a new one (recently moved out and left old one with my 'rents). So it was a spur of the moment thing and I didn't research the new cores. Ended up with the Winchester about a week before the Venice came out... *sigh*
(cf)Eclipse said:if he got it a week before venice, a cbbid is likely
that'll cause serious issues unless you've got a revE coreray4389 said:I went with 3x512
Thanks for the link. Although I already just bought my 2x1024 memory, I'll give it a read. Damn, 10-page article.Wolfsbane2k said:http://amdzone.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=163&page=1
For those looking for an indepth read of some overclocking of 2x1024 sticks.
typhoon43 said:ok,
Now I'm just TOTALLY confused
My rig: Venice 3000+, DFI NF4 SLI-DR
CURRENT RAM: 2 x512 Corsair XPERT3200
2.5-3-3-8-1T @ 256mhz, 2.8 Volts
XPERT timings:
# Timing: 2-3-3-6
Voltage: 2.75V
# Model #: TWINXP1024-3200C2
My BF2 was taking 1.5Gigs Peak Mem, so I want to go to 2 Gigs. BUT, I want to keep my OC on my Venice (currently at 2561 mhz).
I also have in my posession, 2 MORE sticks of XPERT for a 512x 4 combo, and I also have 2 x 1GB OCZ Platinum w/ these specs to try as well:
# Cas Latency: 2
Heat Spreader: Yes
Manufacturer Warranty: Lifetime
Timing: 2-3-2-5
Voltage: 2.6V
# Model #: OCZ4002048ELDCPE-K
So, before I start pulling my hair out and making mad changes to my DFI BIOS, in your humble opinions, which setup should I try to maximize with my rig? 4x512 Corsair or 2 x 1GB OCZ?
I'll sell the XPERT and RMA the other XPERT if I need to, or keep the XPERT and RMA the 2GB OCZ. I just want my BF2 stable without killing my OC or mem bandwidth too bad.
THANK YOU GUYS!!!
Yes, provided two 2x512 pairs can run dual channel.AznAnarchy99 said:so confusing. But for Intel, would i want 2x1024 or 4x512? i know 1T and 2T doesnt make much of a difference but dual channel does in intel. Would it run in dual channel with 4x512?
beowulf7 said:This is an interesting dialog, gentlemen, and one that I plan to research a little and also experiment w/ my system ( a lot), much like how acrh2 has done.
I know in the past, I've read that one should set the initial paging size and the maximum paging size to be the same value. I think we would all agree on that, which would minimize the disk fragmentation done by virtual memory. Also, I read that the paging size should be set to three times the physical memory. That kind of confused me since I figured if one had more physical RAM, it would obviate the need for virtual memory.
Now w/ my 2 GB of physical RAM, if I follow past convention and triple that amount for virtual memory, I'd have to "waste" 6 GB of hard drive space for memory. That ain't gonna happen. So I'll try 0 MB like acrh2 and then maybe try 1 or 2 GB of virtual memory and see what kind of performance I observe. I'd also be interested in others' opinion as well.
WhyYouLoveMe said:That whole "your page file should be x times as much as your RAM" thing is bunk. With so much RAM in systems these days, it's about the total size of your RAM and page file. If you've got 2gb of RAM, you're gonna have PLENTY to spare. (unless you're running 2 instances of BF2... lol) Just make sure that the total of your RAM and page file is higher than the MAX memory used at one time in your system. It's that simple. So... with 2gb of RAM, you should be able to get away with a very small page file or none at all. I've read that some apps hate not having a page file, but I have not seen a problem with zero page file personally. I'm a gamer/internet surfer/e-mailer and I don't do multimedia stuff on my PC. (just to give you an idea where I'm comin' from)
acrh2 said:If by multimedia stuff you meant something like reencoding full length dvd with DivxToDvd, Tmpgenc, or Virtualdubmod, then 2 GB physical + zero virtual memory works for such things just fine.
