The *almost* sub-$1000 i7 build...about to pull the trigger
Tantrix
Gaming 90% of the time, web browsing the other 10%.
Trying to stay around $1000.
3) Where do you live?
Louisiana, the deep South. :cool:
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything.
Not reusing any parts.
6) Will you be overclocking?
Yes, eventually.
Already have a 19" WS running 1440x900 native resolution.
Probably after this weekend, so in 2 days.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Good CPU and memory support, good overclocking ability. I only use single graphics cards so SLI/Crossfire support not a must-have.
10) Do you already have a legit and reusable/transferable OS key/license?
Windows 7 Beta RC Build 7100
Here's the build...short and sweet:
$39.99 - COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel
$499.98 - Combo deal Intel Core i7 920 Nehalem 2.66GHz + ASUS P6T LGA 1366 Intel X58 ATX
$179.99 - EVGA 896-P3-1255-AR GeForce GTX 260 Core 216 896MB
$119.99 - CORSAIR CMPSU-750TX 750W
$84.99 - G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
$74.99 - Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA
$24.99 - LG 22X DVD±R DVD Burner Black SATA
Subtotal: $1,024.92
Shipping: $18.99
Order Total: $1,043.91
Parts look good. Are you going to OC your cpu? You may want to look into a HSF. Also, get the psu somewhere else. Newegg usually charges more. I found one atbuy.com for $105 before $10 rebate.
edit: For $5 more you can get a WD Caviar black 640gb. I think the 640 is faster than the 500gb.
Avoid the Centurion 5. It uses an 80mm case fan for the front -- not the best move you could make.
Go with one of the Cooler Master Elite cases instead. For example, you could buy the Cooler Master Elite 331 -- which supports two 120mm fans -- for $41 shipped.
xigmatek 1283
Get this cooler
i tried thermalright ultra, zalman 9700nt, sunbeam core contact, coolermaster hyper 212. That xigmatek was the best performer in coolermaster haf case. It even beat Thermalright 120 lapped in my system.
I've been eyeballing that Xigmatek, so it's good to hear some first-hand opinions on it. I'm not going with watercooling so it's going to have to be at least a decent aftermarket HSF.
And pay $5 more and get this g-slill memory same clock speed bu better timings
I actually advise against this for 2 reasons:
1. There is no real-world different that you'll notice running at 8-8-8-21 verus 9-9-9-24.
2. The kit you originally selected runs at a lower voltage (1.5v).
You build looks good...all parts look ok.
This is actually the only reason I don't have them on my list...while comparing the two I noticed the lower voltage. If it hadn't been for that I would have jumped all over those 8-8-8-21 for only $5 more.
8-8-8-21 makes no real-world difference that you can notice over 9-9-9-24. It may give you a few extra points in benchmarks. Having the RAM run at a lower voltage is more beneficial than having it run at 1.65v and 8-8-8-21.
Agreed.
You could get away with a good 500-600 watt and save $50-60... put it towards a nicer case..
I originally had the 650w Corsair model, but I went with the 750w model because it has 4 PCI-E connectors while the 650w only has 2 so if I decided to add another GTX 260 I'd be covered there.
I was leery of using a 750w/60a PSU for dual GTX 260s, but I've read that quite a few people are running dual GTX 285s on this PSU so I should be ok.
Heh, up to you, but for an I7 build... why would you wanna put it in a $40 case?
Guess it's personal preference, I'm spendin $250+ on my next case for an I7... and plan to actually keep the case through a few builds instead of a case per build I've been doing.
Oh, the case selection could possibly change before now and order time but I don't care if it's a $40 case as long as it's at least decently built. As far as cooling goes, I always replace stock fans with high RPM ones anyway. Noise is not an issue whatsoever, so I can put in 4k RPM fans in every spot available if I want so I can make even cheaper cases almost take off they have so much airflow.
I know a lot of people can't stand to hear their fans so they buy cases that are designed to have good airflow with even low RPM fans, but like I said noise isn't an issue at all so I can get a cheaper case and spend $7 per fan and fix the cooling issues easily.
What heatsink did you select?
I haven't made up my mind yet, but the Xigmatek S1283V mentioned earlier in the thread looks pretty promising.
Any other recommendations there? I don't want to spend a fortune on one, but I don't want to buy a piece of junk that barely cools better than stock or is hard to install and/or too big.
The Xigmatek Black Knight is a good choice that's also relatively cheap.
But you don't need a dual-card SLI setup to play games on a 19" monitor. Hell, for most games, you wouldn't be able to tell the difference performance-wise between the GTX 260 and the GTS 250. (But the GTX 260 is a steal at its current sale price. It would also be a great long-term video card solution, assuming you don't plan on upgrading anything for at least the next two years.)
Again, you don't really need a 750 watt power supply for one video card. The Antec Earthwatts EA650 is a better choice from a price/performance perspective.
S1283V is probably the best bang-for-the-buck heatsink out there. If you're not chasing every last degree of temperature, it's certainly a good choice.
Other good choices are the Thermalright Ultra 120 Extreme, CoolerMaster V8, and Megahalems.
