I've been using the Coolermaster Elite RC330 for the last bunch of my builds and I have no complaints. Its a good cheap case, shave $30 off your total cost (and put it toward a dif gfx card mentioned in a sec).
Rosewill psus....850W is overkill and theres no chance that PSU would ever reach its rated outputs. Ditch it. I have yet to see a loud seasonic (or corsair), So I vote for either the corsair 450W or the Seasonic 450W.
For an extra $40-$50 you could manage an 8800GS which will give you a significant (3X the shader horsepower, 4X the texture horsepower, get all the data you ever wanted on these two cards here) performance boost in any game.
I dont know what the combo is for because none of those other prices look particularly kick-ass.
Also I am a strong proponent of putting serious consideration into your HDD setup as it impacts performance just as hard as a quad core does in some respects. If you planning on using some old 5400rpm 5 platter 80 gig drive, don't, you can get a brand spankin new 7200.10 160 gig for $50.
Also, an excellent budget overclocking ready CPU cooler is the Freezer 7 pro and can usually be found for $20.
cant use the Coolermaster Elite RC330 , its height is 19.1" and wont fit unde the desk, 17.5" is our limit. will definately look at other power supplies and gpu. for hard drive, we have a seagate 750gig sata drive. thanks for the advice.
Picked the 7600GT as a temp card just to get the rig going, will replace it in 6 mos as 8800/9600 cards come down in price.
CPU : $255-Intel Core 2 Quad Q6600
RAM : $60-G.SKILL 2GB DDR2 1066 PC2-8500
GPU : $65 after $20 rebate-EVGA 256-P2-N615-TX GeForce 7600GT
