The 3D animation / video editing build!
Status
Not open for further replies.
MoreDents
Hey everyone
I'm helping my friend build a new computer and he's a 3D animator. I'm only use to building systems for 2D artists like myself (Photoshop)
To answer the default [H] questions...
  1. It will be for 3D modeling (Maya), video editing and After-effects. Plus gaming :D
  2. Budget is around $1000 - $1200 (w/out monitor)
  3. We live in the United States
  4. We need everything. My biggest concern is the video card. I also would need monitor choices
  5. We'll be reusing no old parts
  6. Won't OC
  7. He doesn't have a monitor. We're thinking of dual 24" possibly...
  8. I plan on building it ASAP. It is spring break :cool:
  9. No need for SLI or RAID. We want to go with 1 high-end video card
  10. As for the OS...should I use XP or Vista and utilize 4+GB of RAM?
Thank you. This will help us immensely. :)
Note:
I did do a search for 3D builds and found this but his budget was $2000 and he wasn't planning on using it for gaming
Admin Edit - One thread per topic, please. Here's a link to the open thread.
Quad core, 4GB ram minimum, 64bit OS and a decent video card.
just a heads up though, if he wants the best performance, he should probably go with a Fire-GL or a Quadro card. I use my GeForce card with 3dsmax and while performance is decent, it would REALLY benefit from the quadro (drivers at least). The Quadros and Fire-GL's tend to display a cleaner picture and faster. However, they're not "great" gaming cards and usually more expensive. The plus side is that you don't NEED top of the line since the CPU is really doing most of the work.
I guess he has to decide if he's going to use it more as a gaming rig or a workstation.
thanks for the reply. I'll definitely look into Quadro or Fire-GL.
I just realized apparently my topic was duplicated! :confused: Mod help please? Thanks!
Status
