The $22 water cooling loop
ne0h
Well I figured since I plan on buying a whole new loop for my system soon it's time to get my hands back in practice of working with water cooling gear. The last water cooled rig I had was back in the days of my Pentium 4 extreme. Oddly enough, this cooler was meant to cool that socket, not the one it will be put on.
I was browsing craigslist last week when I found a water cooled computer for $80. The guy was parting it out and wanted $10 for the water cooling loop. Not knowing what it was (and frankly not caring at all) I told him I wanted it. So after he got back in town I arranged to pick it up. I jumped in my car today after work and drove a couple of minutes to pick it up. Now.. this is where things take a turn.
When I found this ad there were no pictures of the computer, all I had was a part number off the pump. A part number used for both the 80mm and 120mm version of this loop. Like the giddy idiot I was I assumed it was the 120mm. No shock to me (mainly because it's just my luck) I showed up and it was the 80mm version. What ever, ten dollars is ten dollars, you've got to start some where.
So I throw it in the seat and spend the rest of my trip home looking at it laying lifeless in my passenger seat thinking of all the things I may be able to do with it. It's ugly horribly applied TIM, only being stopped from hitting my nice leather by a towel I luckily had in the trunk. I knew first thing was first, it needed cleaning but only slight (so I foolishly thought), and a nice lapping. Then my mind wondered to fans, and then I thought about a res mod. Looking over I noticed the hoses were held on with spring clamps and new immediately it was coming apart.
I bought some computer components off of some one who apparently is (was?) and OCN member near me from craigslist. Among the box of stuff she gave me when i bought a few parts from her was a XSPC res, and a Thermaltake V1 Heatsink of which I found out later the original owner is still an active member. Remembering the res I knew I had to use it, as it wouldn't be suiting for OCN if it wasn't done cheaply while using some hand me down parts. :thumb:
So I get home and I decided I'll start cleaning it. This is what she looked like when I got her on the bench.
She looked dusty, but I didn't think much as it didn't seem to be that bad, and went ahead with the tear down.
And then I hit this...
I figured it may have been from a smoker home, but the dust blew out easily and didn't carry an odor. My guess is it was never serviced and the rig always sat on the floor clear up until the day it was parted out.
So I made a trip to ace hardware to get some stuff (mainly canned air).
What I've gotten accomplished tonight. The build will commence tomorrow.
So I cleaned up the radiator. Thinking about polishing it, any thoughts?
I cleaned the pump up as well.
Pulled the res out of my case:
Mounted the barbs in it:
And then I started working on lapping the block/pump combo.
After twenty minutes of dry sanding with 2000 Grit:
After Sanding with 2500 Grit and polishing:
The goal is that tomorrow night I'll have the loop all laid out, the fans mounted to the rad, all the wiring and tubing done, and have leak testing underway.
So I'm actually going to repolish that block tomorrow, I'm not happy with it. If you look near the center in the photos there's a nib from the machining process. I'll DA this flat and then step through it and polish it.
Also, I have to make a bracket for this as the bracket I have is for intel. Things are going to get interesting....
nice scores! looking forward to seeing how it turns out.
Subbed!
Its amazing how dirty that thing was, I wonder if the original owners noticed any performance downgrades.
I'm surprised that thing even worked with that much build-up:eek:.
Great job. Looking good.;)
love seeing scruffy old hardware cleaned up and repurposed.
i recon that old 80mm rad was neglected even longer than my 360 rad was (snapped during my case rebuild).
i'm curious as to what you'll be attaching your 'bargin basement' WC parts to.
don't forget to post lots of pics.
damn man that was some nasty looking dirt. i woulda cleaned that shit outside before i brought it in the house. good clean up job though!
OP, make sure you use appropriate coolant to the block and radiator. I'll bet money you'll need to use an antifreeze mix to avoid alu/cu corrosion. I'd be very surprised if that isn't an Alu radiator.
Luckily I've got a dyson so clean up was kind of a non issue. I did take it out side to blow the dust out though after vacuuming the bulk of it.
It's my guess that no one has ever done that. The block is copper and the rad is aluminum. Blue corrosion came out of both. For the money, I'm not even going to worry about it. I'm going to pick up more WC stuff tomorrow for my actual loop, so this is just kind of a project of sorts.
great job man, those are some old school WC parts lol
Thanks man :)
Yeah, the parts are pretty ancient. This is meant for like Socket A, 754, and I think 939 and 940. And then the clips that I have are for the intel sockets, so I'll have to make my own mounting hardware as well.
Damn, for the longest time I've been tempted to rummage through my old boxes and dig out my DD Maze4/eheim 1250/black ice radiators loop I put together back in freshmen year of high school, but I'm reluctant/lazy to fabricate a bracket or mount to fit on my 2500k. If I were to do that I'd probably ghetto rig my current Antec Kuhler 620 to my video card lol
Great work! Can't wait to see it running and it'll probably inspire me to make use of my old crap as well.
An update of sorts....
Last night I went ahead and flushed out everything a few times. Here's what came out:
So some stuff came out. Then I flushed it in the sink for a bit and a TON more stuff came out, almost as much as when I flushed it when I first got it. So I filled it back up with distilled water and ran it for a bit to flush it out some more. Drained it, refilled it again, ran it for a while, drained it.
You'll notice there's some water on the desk. Part of it's from me spilling when filling, the other is from the barbs leaking. I didn't put any poly tape on them when they were first installed, so I went ahead and took care of that as well.
Now it's sitting, it's been sitting next to the heater for a bit to dry it all out before I fit it to the computer. I'll have to cut a bracket more then likely to get it to fit the AM3 socket. After looking at the one I have, I can't flatten the tabs enough to get the extra metal lenth I need for the pattern to match. So I'll make a template from plastic, and then trace it to a piece of plate and cut it.
I nearly spat out burrito all over my beautiful ASUS LED monitor as I had JUST taken a nice large bite right when I scrolled down to the dust pic...
Thanks for the giggle :p
