that shiny look
leSLIe
i´ve recently painted a new case with just some spray paint, looks good but it doesn´t look shiny, the way new cars do, for that nice shiny look a coat of some transparent stuff is applied, so i was wondering if NE1 knows exactly was that stuff is and some good brands, i really would like to have a nice shiny case.
thanx
If you only painted it with spray paint would first need wet sand. After that you would spray it with several coats of clear to give the paint some depth. Then color sand and rub it out with compound. There are several guides on the net, do a search on google.
It's called clearcoat.
Wait about 3-4 days before applying it... And apply a good 5-10 layers of it, waiting a day inbetween.
Wait 2 weeks after the last coat of clear-coat, and buff it up with some car wax or something.
