Thank you RAID 1
  • Thread starter Deleted member 19858
  • Start date
D
Guest
My server for ocmodshop.com has a RAID 1 setup with 2 18GB SCSI drives in it and it looks like one of them died so the system failed over to the other one. I have not actually had a chance to get down to my server to see if it really did die but if it did the RAID setup saved my data. Hopefully its not dead or if it is I can RMA it otherwise I gotta try and find another matched drive to redo the RAID.
Glad to hear you didn't try to run a striped array to get better HD Tach numbers ;)
Yule Bryner is right of course even if Westworld wasn't too great: you should have your data backed up off the serving site in another medium anyway. Why not invest in a cheap external USB HDD as a backup and burn the contents to DVD at home once in a while?
I know I should have been backing up which is why I got free DSS1 tape drive from work which will back up 4GB of needed information daily. I would like to get a DLT but I dont have the money. For now I can backup my SQL, IIS, Exchange, and system state no problem.
