I'm trying to flash DD-WRT onto this LaFonera.
Seems to be working- I got my hopes up.
I've been following this guide to a T:
http://uselesshacks.com/?p=23
Now, my problem comes into play when I start to use Tftpd32 and try to load the files.
It just keeps timing out- never finds them.
I'm using PuTTy as my telnet application. Everything was done exactly like in that guide...
They are in the same directory as Tftpd32.exe. The location is pointing to them.
I just don't understand why it isn't finding this stuff...
This Tftpd32.exe almost seems TOO easy. Do I just start it- and that's the end? It seems like I should be trying to specify which files to serve or something, but I don't see the option for it, and nor does the guide specify to do anything else.
Any of you have any ideas? I've unblocked all ports and stuff.
Like I said- everything else went without a glitch until I got to the TFTP server. Something that SHOULD be easy, but obviously is causing me problems.
