TForce 939 ownders using Team Speak
MassiveOverkill
I'm using the onboard sound with the front mic/headphone front header plugged in. Whenever I'm on Team Speak, people hear themselves echo and can hear my windows sounds. I sound fine on my end. I don't echo on their end, just their own voices.......and it only happens when I join TS. It's not feed back from my mic. Anyone else have this problem?
The most common problem is usually people have teamspeak not set to push to talk (activate on sound), that would cause the mic to go off at any sound coming from the game and what not. If you really need to have it set to that option, try lowering the sensitivity in teamspeak. Or, you can just set it to push to talk and bind the key to something.
another common error could be that your mic is set to "what you hear"(creative sound cards) or "stereo mix" (nforce onboard).
thats about all i can think of if it isnt a tforce thing.
