tForce 6100 vs. 6150
Ok beside the faster onboard video, what makes the tForce 6150 better than 6100? i really want to buy the Biostar 6100-939 but i do not want to screw myself because i did not wait for the 6150! I just want a stable overclocking mobo with good features that should last me awhile. So will the 6150 have better features or will it have better onboard video? i dont need the onboard video because i have a 7800gtx.
The difference between 6150 and 6100 is just onboard video.
What you also have to consider is the difference between 430 and 410. 430 has 4 SATA ports and Gigabit lan while 410 has 2 SATA ports and 10/100 lan. Also think the 430 has a firewire port while the 410 doesnt. There are some other differences as well.
Choose which ever board gives you the best combination of features you want. For OCing capabilities you would have to check reviews.
EDIT: Here is the comparison table :D
Thanks. When are 6150 mobos due to be out. I read in the inquirer that Asus and MSI will not be ot until mid november but Biostar is ontime with there 6150. When biostar says tehy are "ontime" how long from now are they referrring too. I do want to ahve all the beniefits the 430 southbridge has i jsut do not know how long I am willing to wait. So my question is: Does anyone have any idea when we will begin to see 6150+430 mobos?
There is a bigger list here. Most of those features are not dependent on the chipset, but the 410 vs 430 southbridge like Crazy was saying.
http://forums.extremeoverclocking.com/showthread.php?t=194155
The only thing that I can see that might consistently be missed is the DVI port. Firewire and SATA might be issues for you too. Modern games are basically unplayable on both onboard chipsets, so that should not really be a deciding factor: http://www.overclockersonline.com/index.php?page=articles&num=317&pnum=8
